1981 Honda Civic Stick Shift Tight/Sticky
Old 09-25-2007 | 05:48 PM
sir_nasty's Avatar
Default 1981 Honda Civic Stick Shift Tight/Sticky
So yes I'm aware that this may belong in the civic forum but since I was here already.....
The stick shift in my 81 Civic is rather thight/sticky/stiff, the linkage is fine and free and I've tried some lubricant in it but it doesn't seem to do a whole lot. Any of you old school honda guru's ever come accross this? I've heard rumors that there was a teflon ring in there and that because the stick sits right above the cat converter it gets hot and deteriorates but I can't confirm any of this. Advice, Suggestions, Thoughts anyone?
Old 09-25-2007 | 09:22 PM
deserthonda's Avatar
Default RE: 1981 Honda Civic Stick Shift Tight/Sticky
I have seen it where you have to replace the lower shifter rod bushings ,, raise the car up, remove the 12 mm bolt ?nut and see if lever moves freely ,, if it does,throw in a set of bushings , there 2 bushings and a nipple that goes inside them .. Once you see it , it is self explanatory .
strokera4
01-31-2011 01:05 PM
xbox1986
05-25-2008 02:01 AM
sarmac415
12-15-2007 03:09 AM
GalenMan679
11-12-2007 06:05 PM
reeling
08-15-2007 06:06 PM
