1988 Accord will not run
Old 11-07-2008 | 11:59 AM
yeoldaccord
Default 1988 Accord will not run
I'm working on an 88 Accord 4 cyl, has about 350K miles or so, dont know if its the factory engine or not. Here is the problem. It has been running quite poorly the last few days (wont hold idle, misfiring) and now it will barely run at all. Cranks over and attempts to fire but it wont take off. Checked out the plugs and ive got a very weak spark on 1 and 3 and very strong spark on 2 and 4. Changed plugs and wires to no avail. Holding throttle open will get it to spin up and run at about 1000rpm if it starts at all. We have smoke coming from under the hood and a cherry red exhaust pipe when we can get it to run, so something is causing excessive heat (maybe unburned fuel). fuel doesnt seem to be an issue, we can smell it and we have black smoke out the tailpipe. It seems to be the lack of spark on 1 and 3 that is the problem.
Old 11-07-2008 | 12:01 PM
falkore24's Avatar
Default RE: 1988 Accord will not run
Look for burns on the contacts inside the dizzy cap.
Old 11-07-2008 | 06:21 PM
hondadude's Avatar
DX[manual windows]LX[ power windows]or LXi [sunroof]? does it have a carb or fuel injectors?
Sheesh, it's not as if weneed to know what color it is.
Old 11-08-2008 | 12:54 AM
yeoldaccord
LX
Old 11-08-2008 | 01:38 AM
X2 on the suggestion to replace distributor cap and rotor. Replace the maintenance items first before testing some other items.
Is your check engine light on, and have you checked for any error codes?
Old 11-08-2008 | 11:49 AM
yeoldaccord
no it isnt throwing a CEL, that is if the light even works. ill check out the cap. Thanks everyone keep em coming!
Old 11-09-2008 | 05:41 PM
If you checked the spark by a good consistent method, same for all plugs, then you ALREADY KNOW its a spark problem in only 2 plugs.
New plugs & new wires, right? Any chance they are defective?
Any problem with the coil, ignitor, or anything upstream from there would screw up all 4 sparks. That pretty muchnarrows it down tothe cap & rotor...
raydavid93
03-16-2013 10:23 AM
Nathan Mounts
01-19-2013 08:57 PM
franky831
12-08-2010 09:01 PM
wal
12-07-2010 07:41 PM
boostedtsi
10-28-2008 07:39 AM
Quick Reply: 1988 Accord will not run
