1988 Honda Accord LX wont start
Old 04-20-2008 | 11:55 AM
russo_p
Default 1988 Honda Accord LX wont start
Hello,
I have a 1988 Honda Accord LX (carb model) that won't start. Car does crank, there is a fuel smell as well. I have replaced the ignitor (hitachi distributor), distributor cap, and rotor. I did measure the coil resistance and its in within specs but on the low side. I did see a spark from the coil wire to the distributor but no spark at the spark plug side. Should I replace the coil, even though its in specs but not mid-range? What else can I try?
Thanks
Old 04-20-2008 | 04:36 PM
Default RE: 1988 Honda Accord LX wont start
I have seen coils with the proper resistance that are still bad.
If you are not getting spark to the plugs, the coil is likelyl bad since you already switched the ICM, dist cap, and rotor.
Old 04-23-2008 | 12:09 AM
brickballer's Avatar
How the heck did you verify spark between the coil and distributor? I'm pretty sure it's not good for your ignition system to pull the main coil wire and hold it close.
This may be a stupid question, but are you sure you have the right cap and rotor?
raydavid93
03-16-2013 10:23 AM
gasface11
07-11-2012 01:33 PM
Hanktjy
03-25-2012 07:03 AM
Hanktjy
03-08-2012 09:53 AM
kylefaust
09-07-2008 03:48 AM
