1989 accord low beam problem
Old 01-08-2010 | 08:39 PM
dman1049's Avatar
Default 1989 accord low beam problem
its an 89 accord 2 door, high beams work but not low beams anyone have any ideas on what could be the problem? the main fuse box under the hood has been checked and all were fine.
Old 01-08-2010 | 09:35 PM
There should be two fuses, one for each of the low beams. Those fuses are probably in the fuse box under the driver's side of the dash. Check those first to see if they aren't both blown.
If not, then see if you have 12V on the wire at the low beam bulb plug (it should be the non-black wire) when you have the low beams turned on. This will determine if the problem is with the power side of the circuit or the ground side. Just grab a volt meter, and touch the red probe to the non-black pin, and the black probe to a bolt on the valve cover.
Old 01-09-2010 | 01:51 PM
Don't forget to check for burned-out bulbs.
hallstevenson
08-08-2013 12:27 PM
kouken
11-11-2007 07:48 PM
madtexan69
11-06-2007 03:17 PM
HondaAccordNewb
10-18-2007 07:51 AM
mngantung
08-05-2006 03:22 PM
Quick Reply: 1989 accord low beam problem
