1990 accord lx hesitation issue???
Old 01-10-2008 | 10:05 PM
f22a1accord
Default 1990 accord lx hesitation issue???
I have a 1990 accord lx 2.2l SOHC non-vetc with a CAI and full exhaust. the problem is when im giving it steady throtle while going through my gears it hesitates when i hit the next gear between like 2500rpms to 4000prms? any ideas? cause im stumped on this one.
Old 01-11-2008 | 08:25 AM
Default RE: 1990 accord lx hesitation issue???
If you mean the engine slightly overspeeds during the shift and shift is delayed, this is usually a symptom of aging automatic trans. It may help to drain, refill, run 10mins,and repeat3-4 times to replace most of the fluid in the trans. Honda ATF is consensus best fluid. Check ebay for reasonable prices on Honda ATF.
If you slightly let off gas, the shift will usually go ahead. I know this is not normal, but my brother has nursed a Toyota Camry for years w/ this procedure.
A rebuilt or used trans may be only true fix. For a 90 Accord you'll spend more than the car is worth.
Old 01-11-2008 | 04:22 PM
I'm not sure what you mean either. It could be the tranny, but...
When I hear of a stumble around 2000 rpms, I would suggest cleaning the EGR ports.
Search T2T013.pdf on google and you will find a pdf on how to clean those out. Its something simple/cheap to do, and it might fix the problem. Hondas are known to have those ports plugged up.
bushcal
08-08-2012 02:56 PM
keno16
01-24-2009 08:00 AM
daddave
02-07-2007 04:01 AM
joe592
09-09-2006 05:34 PM
