1990 honda AC
Yeah, that'll cause uneven temperature across the face of the evaporator. Incorrect pressure can cause that too. Try a can with dye so you can find the leak. Or find a shop with a leak detector (sniffer).
After you fix the leak then have it evacuated & filled by weight. That's more accurate than filling by pressure. (But filling by pressure is way more accurate then just guessing) Adding cans of refrigerant & bleeding it out is a real poor way to remove the air. It'll take forever to get all the air out.
Air in your system will cause it to run poorly. Air doesn't compress to a liquid like R134a, and it won't bleed out.
Jim is correct, you need to find and fix the leak.
You car is 20 years old, so all of the o-rings are probably brittle. A bad shaft seal is another location for a leak.
What I did was dismantled the system. Replaced all of the o-rings and used Nylog o-ring lubricant to help keep the rings lubricated. I replaced the shaft seal (I can give you more detailed instructions), because I wanted to make sure that I did it right the first time and would not have to repair the a/c for a long time. I also bought a new receiver/drier and expansion valve. I drained all of the oil from the system, and used oil that was made for R134a. Once the system was back together, I pulled a vacuum to remove the air, and waited for an hour to make sure it held a vacuum (it did). Then I added the R134a. It has been working fine since then.
gnozahs
08-03-2007 05:09 PM
loopster
05-20-2007 11:27 AM
