1991 Honda Accord LX 4cyl, 2door turns over but won't start
Old 08-21-2011 | 10:27 PM
Lch05Srm's Avatar
Question 1991 Honda Accord LX 4cyl, 2door turns over but won't start
Car quick starting suddenly. Would only turn over but never start. My husband replaced main relay but still doing the same, only turning over without starting, but this time noticed strong smell of gas when attempting to start it. Any advice on what the problem might be since replacing the main relay didn't solve our issue? Thanks
Old 08-22-2011 | 12:27 AM
bigpat's Avatar
Almost A Senior Member
Likely an ignition fault of some sort. Check for spark at the plugs, and also test the coil/ignitor for correct voltage. Use a timing light to check each spark plug wire for voltage from the coil/ignitor to the plugs. Replace the distributor cap and rotor as well. I would also carefully hunt for the source of the fuel smell as this could be dangerous. Keep us informed and good luck.
HondaaAccorddGuy
04-08-2013 06:54 PM
bilbobagins
09-21-2012 11:56 PM
jmalek
11-07-2011 12:24 PM
themachinist1
06-22-2011 07:41 PM
vynum
06-06-2010 09:29 PM
