1991 transmission problem code 7
The sport light flashes as soon as I shift into drive. The code I retrieved was seven(solenoid A lock up). I removed solenoid, cleaned it, and tested it. I put it back on, cleared the code. And I still have the same problem. Do I need to get a new solenoid or TCM or other? Any suggestion will be appreciated.
Thank you.
Thank you.
postred
07-11-2007 01:35 PM
