1992 Honda Accord f22a1 dtc 15????
Old 11-20-2010 | 05:34 PM
nicholas.barabas's Avatar
Default 1992 Honda Accord f22a1 dtc 15????
ive replaced the coil and the ignitor in the distributer is fine i had it checked today the car will turn over and fire fine itll idle perfect nothing sounds wrong but after a few minutes it just cuts off and ive came to a wall idk wat to check or wat to try so hopefully somone can help me out here please its throwing the dtc 15 which is the ignition output signal
Old 11-20-2010 | 05:51 PM
Check the wiring to the ignitor. If no shoddy repair work has been done, then see if you can get the car to stall by shaking the key when it is running.
It sounds like you have and ignitor problem, but do those tests first. O'Reillys can test ignitors. Have them repeat the test, because it might fail after it heats up.
Code 15, ignition output signal, means that the ECU has found the inition module (igniter) signal is not received by the ECU which indicates that the igniter is dead, has a loose connection or has failed intermittently. The ECU looks for the 10V reference signal from the igniter. If the car won't start because of this code then check for a loose connection or replace the igniter.
Old 11-20-2010 | 06:08 PM
had it tested and its fine no repair work on the wiring its all good the car will start fine it jsut shuts off completely after idling few minutes then wont start again
Old 11-20-2010 | 06:17 PM
How about the part where you shake the key when the car is running?
The two pages below show the electrical testing for a code 15. The problem could be the ignitor, the wiring, or the ECU.
If you have a volt meter, test for 12V like on pg 6-185. You will not have the test harness for testing the input to the ECU on 6-186, but you can check those pins on the ECU to see if they are loose or corroded.
Let us know what you find.
media.honda.co.uk/car/owner/media/manuals/accordManual/400/6-184.pdf
media.honda.co.uk/car/owner/media/manuals/accordManual/400/6-186.pdf
rjpjnk
06-16-2016 12:40 PM
rockhoundrob
04-01-2015 11:08 AM
04-02-2014 06:00 PM
SPAMHATERLEE
03-10-2008 07:44 PM
VTach
12-08-2006 02:05 AM
