1993 accord dx will not make a sound
Old 08-06-2009 | 07:56 AM
rgstanley1
Default 1993 accord dx will not make a sound
I replaced a bad transmission shift solenoid, radiator and thermostat. But I broke the bottom bolt off in the thermostat housing that held the grounding cable. the engine will not make a sound. everything appears to be working fine main relay and and the fuel pump. I am not getting any trouble codes.
i bolted the ground cable to one of the other bolts on the thermostat housing.
Old 08-06-2009 | 11:46 AM
00AccordLX5spd's Avatar
Registered User
What do you mean will not make a sound? Like it wont turn over? Does it click? Do the electrical components work?
It has got to be something to do with that ground cable (if the car was fine before that happened). It's probably not getting good ground fromt he other bolt you attached it to.
Old 08-06-2009 | 01:24 PM
What I don't understand is; losing that ground connection shouldn't prevent the starter from working. You could lose fuel or spark, but the starter would still run.
While you were doing the shift solenoids, would you have (accidentally) removed the small wire from the starter?
Old 08-06-2009 | 03:21 PM
deserthonda's Avatar
that ground wire is the main ground for the ecu,, it will not keep the engine from turning it will keep it from starting,,
dash lites on when key in on position ?? chk battery cables ,+ wires going to starter Jim might have hit it on the head about the starter wire possibly being off,, if cables ok,, chk the main fuses maybe you accidentally blew one ,,
Old 08-06-2009 | 07:55 PM
rgstanley1
I accidently removed the wire from starter. The car is running again.
Thanks for your time!
Old 08-07-2009 | 10:50 AM
Registered User
Thanks for posting the fix. Dangit I was wrong again! I can't seem to get much right these days. Nobody listen to me anymore haha!
Old 08-07-2009 | 12:30 PM
Originally Posted by 00AccordLX5spd
... Nobody listen to me anymore haha!
What do you mean ANYMORE?
(Just kidding you help out lots of people around here.)
Old 08-07-2009 | 01:48 PM
thanks for posting the fix............that Jim guy hit it right on the head , he sure knows his stuff..i am so glad that he is part of this forum ...
Old 08-07-2009 | 09:50 PM
Smile
That's why I made him a Super Mod Gianni..By the Way JIM lives in my garage here in my town..)
cat2115
04-26-2014 08:49 AM
Lucyy
07-01-2012 04:38 PM
93Accord2.2
02-08-2012 01:50 PM
ryandamartini
12-11-2011 11:16 AM
kennilope
01-29-2008 05:59 PM
