1993 Accord: Power windows control panel. Drivers side.
I need to know how to remove and replace the control panel for the front drivers side power windows switches.
Of the four switches to raise / lower the windows, the 2 passenger side work fine and properly but the drivers side front and back window switches have no response. I've been told that the motors were tested and are fine, it's something in the switch itself.
The power lock switch at the same spot half works. Sounds like it's trying to engage or disengage the lock, but doesn't really succeed. Just moves a little and only something like one of 5 times does it actually work, BUT if i use my key in the door to lock the car, the power switching of all locks work fine.
So, it's all bad in the switch panel, right?
Creepyjeeper
05-26-2012 04:48 PM
1993, accord, door, drivers, electrical, honda, panel, power, power locks, power windows, remove, removing, side, switch, window
