1994 Accord VTEC Engine/Trans Vibration
Old 11-24-2008 | 03:18 PM
mbnjagn
Default 1994 Accord VTEC Engine/Trans Vibration
Hi All.
I have an odd thing happening to our 1994 Honda Accord VTEC with 191,000 miles. Between 2000 and 2500 RPMs on acceleration I get a pretty bad vibration. It mostly happens when it is in 4th gear but I have felt it at other speeds as well. I thought I remembered reading here someplace that it may be the torque converter starting to go out on the transmission. The other day I decided to check the spark plugs thinking it may be a missfire, but why would it just be at that RPM? I pulled all plugs, one had some oil on it from a leaking o-ring gasket but looked ok, but on the next 2 cylinders the spark plugs were all covered with a light powdery substance which I was told was a symptom of just running hot. I replaced the plugs and nothing changed. Before I take it in to the dealer and pay $120 just to have it looked at I wanted to ask the question here. Any ideas?
Thanks!!
Old 11-24-2008 | 04:22 PM
Default RE: 1994 Accord VTEC Engine/Trans Vibration
How much oil on the one plug? Enough to short some of the spark to ground? Fuel mixture is more difficult to ignite at some loads & rpms, so a marginalweak spark can misfire under some conditions & fire OK otherwise.
Open the hood after dark, turn out all the lights, start the engine. Look for arcing around the cap & plug wires.
Old 11-24-2008 | 04:47 PM
mbnjagn
Hi.
I was thinking the same thing about the oil shorting the plug but I do not think it was enough to get up into the top of the plug. Wouldn't it affect the engine at all RPMs then if it was shorting? I did also try to look for arcing spark with the lights out, nothing.
Thanks.
Old 11-24-2008 | 07:41 PM
If it was only shorting out a little bit(?), it could misfire in some conditions, but fire OK in conditions where the mixture was easy to ignite.
WhatI wanted was for you to check it, & it sounds like you did that & ruled it out.
Old 01-02-2009 | 03:09 PM
mbnjagn
Hi All.
Just an update. I did find out what the problem was, it was the exhaust gas recirculation system which is located under the fuel rail. 3 of the 5 ports were blocked solid. Cleaned those out and put it back together and the problem was gone.
Old 01-03-2009 | 12:16 AM
Thanks for letting us know.
cd51994accord
01-30-2014 01:56 PM
blahblahfoo
02-19-2012 01:00 AM
1955Joe
08-29-2011 04:32 AM
spazzin360
09-29-2010 09:29 PM
huzzsaba
12-04-2006 09:23 PM
