1994 Honda Accord brake vibration not going away!! Please help!
Old 02-01-2010 | 03:23 PM
spazzin360's Avatar
Here is the link of the instructions I followed to replace the front rotors....
http://www.power-21.com/Federalmogul.../Docs/3501.pdf
Old 02-02-2010 | 08:18 PM
kris_loehr's Avatar
That is a slick way of doing the rotor job.
Old 02-03-2010 | 09:31 AM
spazzin360's Avatar
Hey guys!
I got the Honda back from the shop that machined the rotors on the car. It feels like ALL of the vibration it FINALLY gone!! I've only had a chance to take it up to 60mph and hit the brakes once so far, but it did not vibrate AT ALL. It always vibrated when braking before, so I am pretty sure its all fixed. I found a place that had an on the car lathe and would machine the front rotors for only $80, well worth it!
I will post again if I feel vibration again, but as of now, I am saying that was the fix. Thank you guys SOOO much for the help!! I would have never figured out that the new rotors could be warped out of the box.
Thank you HondaDude! You got it.
Thanks again everyone!
Old 02-03-2010 | 06:29 PM
kris_loehr's Avatar
When I worked as a used car mechanic we put new rotors on front wheel drive Chrysler product but didn’t drive beforehand. When you hit the brakes it made a loud thump like a bad suspension component but no pulsating. We couldn’t find anything worn and ended up taking it to the dealer which cut the rotors on the car and that took care of it. In taking to the parts store they said it was common to have them warped in the box if made in China this was early nineties. Now when I go to the parts store I see none of the big names in brake parts I know or a name brand with made in Asia in little print. I buy the factory parts as much as I can.
Occasion the hub for the rotor will be bad and give you pulsation but not very often. With cutting them on the car you covered both hub and rotor.
Old 02-10-2010 | 02:43 PM
spazzin360's Avatar
I still can't believe that they sell rotors warped out of the box....crazy. Well that was the fix, I just had to have them machined on the car...So if other people have this same problem, that is definately what I would try.
THANK YOU GUYS AGAIN!!!
Old 09-29-2010 | 09:29 PM
erendresen's Avatar
everybody misses this. if it isnt a bad rim or tire, it is a bad wheel bearing...worn and allows too much free play
94ex915
09-17-2012 10:01 PM
atlsk8crewboi22
09-06-2009 04:04 AM
GolfingTiger
12-17-2008 12:28 PM
markinchico43
01-20-2008 09:34 PM
