But if the problem was a mount, it would happen both on cold engine temperatura and hot.
It only happens on hot, hence my assumption its the ATF+4 thins out too much on hot operation?
Could be, there is no harm to do another drain and fill with the Honda fluid. I'd get enoguh for a third if needed...plus sometimes you can "deal" on larger quantities.
