1994 inner tie rod ends
Sorry for the delay.....just get the pieces (spacer and new lock washer) back in the right place/order. Take your time with the vent tube on the boots. Of couse check the outer tie rods while there. I also suggest you have the alignment checked after the work.
Thanks for the advice, I'm doing the outer ball joints & axles at the same time, so no prob: my home is 1/4 mi from the alignment shop, & I'm pretty good at getting it roughly right.
Also have had a number of Saabs (among other obscuratta) and Detroit iron: fun stuff.
