1995 accord ex vetec distributor leak
How do you replace the distributors internal seal? It looks like you have to press the bearings out to remove the rubber seal. Has anyone done this before or do I have to take it to the shop? Thx
Yes, I've done this and it is not terribly difficult, but installing the seal can be tricky. It is tight and easy to damage the seal.
See following link for instructions. I found that I did not need to remove the sensors as this procedure indicates.
http://techauto.awardspace.com/conte...orexploded.php
grkacl
09-20-2009 12:35 AM
