1995 Accord Runs Rough Just Above Idle
Old 05-02-2011 | 07:08 AM
rlc138's Avatar
Default 1995 Accord Runs Rough Just Above Idle
Hi:
Regardless of load, speed, or rpm, my 1995 accord EX 2.2 VTEC automatic runs rough (stuttering, sputtering) at cracked throttle (approx 1%-5% open). At 5%-100% it runs fine.
The car is all stock and has 180,000 miles.
The check engine light is not on (but verfied that it is functional). I thought it might be the O2 sensor, so I checked it with the volt meter according to the Hanes manual and it appears ok. As a second check, I disconnected the sensor and ran the car and the problem persists.
Nothing has been done to the car recently. The problem started suddenly without provocation.
I looked at the vacuum lines and did not see anything suspicious.
The car idles fine and runs normal at >5% throttle.
Does anybody have an idea as to what could be the problem here?
Rob
Old 05-02-2011 | 08:48 PM
No CEL....all reg maint items up to date (cap, rotor, plugs,ect). A few ideas of where to start, most don't cost much.
A good TB cleaning, along with inspecting/cleaning/adjusting the FITV and IAC.
You say it doesn't matter about load and that but what about engine temp....all the time or just when the engine is warm.
Old 05-03-2011 | 11:51 AM
rlc138's Avatar
Good question - I forgot to mention that it runs fine when it is cold. After about two or three minutes it starts to act up and then continues until engine is cooled down.
Old 05-03-2011 | 07:16 PM
Another clue...two to three minutes isn't enough for the egr to come into play, so cleaning the ports is out (?). So I'm going to go with the FITV and or the IAC needs a bit of cleaning/adjusting. Should be a "how to" in th DIY section.
Again, the other maint items are up to date?
mikelac
07-17-2014 02:36 PM
chris30721
01-06-2011 08:06 AM
JoetheEngineer869
03-31-2010 06:57 AM
Accord Pete
01-31-2010 02:50 PM
Dan50
02-05-2009 07:30 PM
Quick Reply: 1995 Accord Runs Rough Just Above Idle
