1995 honda accord lx 4cyl...A/C wont turn on!!!
Old 11-20-2010 | 04:42 PM
nicronecro's Avatar
Default 1995 honda accord lx 4cyl...A/C wont turn on!!!
The air conditioner my the car stopped working around march april. None of the lights turn on for it. It rarely and randomly turns on but only for seconds at a time. I dont have the money for an electrician and wanted to try it on my own.
Old 11-20-2010 | 04:58 PM
Not much to go on. I'd have the system presure tested. Does the heat work,,,,blower works but no cold air. Rad fans come on when the a/c does work.
If you are ok with working on it yourself, get the manual-if you don't already, check/search the DIY section for places to get one- work your way back from the compressor to find out why the power is not getting to the compressor.
Old 11-20-2010 | 05:59 PM
You will need a volt meter. You need to know how to read voltage and open/closed circuit to do the tests.
You should also download the 94 shop manual from the spooner link in the online manuals thread in the DIY section.
Check the #8 fuse in the box under the driver's dash. See pic for fuse location.
Also, does the blower inside the car work?
Attached Thumbnails 1995 honda accord lx 4cyl...A/C wont turn on!!!-fuse.jpg
Old 11-23-2010 | 01:44 AM
nicronecro's Avatar
At first the A/C would work hot and cold then the cold air stopped blowing. Then the A/C would run then turn off. Now it wont turn on at all. None of the lights will turn on that would normally designate which button was in use but the lights for description will turn on when i use regular car lights, like normal.
Old 11-23-2010 | 04:39 AM
You did not answer my question. Does air of any temperature blow out of the vents?
Old 11-23-2010 | 09:58 AM
adr5's Avatar
AC systems have a pressure switch that keeps the compressor off if the refrigerant leaks out of the system. This is to keep the compressor from running without the refrigerant, which also has lubricant in it. So you should first check the system to see that you have enough refrigerant in there.
Old 11-23-2010 | 11:10 AM
nicronecro's Avatar
no air bows at all
Old 11-23-2010 | 05:01 PM
In that case, first check out why the blower motor doesn't work. Fuses? Burned-out motor?
Old 11-24-2010 | 02:07 AM
nicronecro's Avatar
I don't know if this helps but my rear defroster button also does not work. All of the buttons directly connected with A/C console do not work. No power is going to it at all.
Old 11-24-2010 | 02:47 AM
All of those items are protected by the #8 fuse I mentioned in a previous post. Did you check to see if that fuse was good? You can try replacing with a new fuse.
