1995 honda accord vacuum leak
Old 03-15-2020, 08:06 PM
slimjim702's Avatar
Default 1995 honda accord vacuum leak
Hey everyone
My name is robert I'm having some problems with my 1995 honda accord ex 2.2 M/T. 4 cylinder
I have been have problems with misfiring on cylinder number 1. Changed out the spark plugs the wire and the hole Distributor. After I started the car it ran great. Took it for a drive and came back. The car sounds like crap. So I check the fuel injectors and there running good. I went as far as changing the number one injector. I cant figure it out...then I came across a vacuum leak and I dont know when to connect it to. I looked all over and nother. Here is some pics.
I put my finger over it and it still sounds like ****. I dont know what it could be. I also did a compression test
1- 180psi
2- 170psi
3- 175psi
4- 180psi
I dont know what else to look at. Please help me on both of these problems.
Old 03-15-2020, 09:15 PM
The top looks like it goes to the EGR valve. The middle goes to cruise control. You shouldn't have a bottom port, because your car is a manual transmission accord and doesn't have a vacuum modulated rear motor mount.
There should be a hose connecting that port to the horizontal tube below where the word line is written in red on the first picture.
Old 03-15-2020, 10:07 PM
Seanjordan20's Avatar
That port should be capped off. It was only used for automatics going to the electronic control mounting solenoid. It has nothing to do with your engine running bad.
Old 03-15-2020, 10:11 PM
slimjim702's Avatar
Originally Posted by Seanjordan20
That port should be capped off. It has nothing to do with your engine running bad.
ok thank you. Any idea on my other problem
Old 03-15-2020, 10:12 PM
Do you ah e any code being thrown?
Old 03-15-2020, 10:13 PM
slimjim702's Avatar
No codes
Old 03-15-2020, 10:21 PM
Your compressions are off on 2 and 3 but should not effect 1. Did you check your valve lash. Number one could be too tight.
Old 03-15-2020, 10:22 PM
Also what brand distributor did you use.
Old 03-15-2020, 10:32 PM
Had you cleaned the EGR and ports?
slimjim702's Avatar
Duralast is the brand
Quick Reply: 1995 honda accord vacuum leak
