1995 honda accord vacuum leak
Old 03-15-2020, 10:36 PM
Seanjordan20's Avatar
Just giving some other options. If the valve lash is good and the EGR/ports are cleaned you can try a smoke test possibly a new fuel filter (even though that would cause random misfires if bad). Possibly cleaning the PCV and MAF. Check the catalytic converter to see if it's clogged/rattling.
slimjim702's Avatar
I'll have to check that
Old 03-16-2020, 03:45 PM
Your compression numbers are good and all within range, so I would recommend not touching the valves.
Please tell us more about what was done to the car right before you started having the misfire? Was any work done on the car, or did you notice the problem after filling up the gas tank?
How did you determine that #1 cylinder was misfiring?
How long were you having the problem before you replaced the distributor? Has the same problem returned since you replaced the distributor, or is the problem something different?
Didn't get a good look at your pictures yesterday. Plug up that open port with a cap. Remove the 7.5 amp backup/radio fuse in the engine bay fuse box for a minute, then reinstall the fuse to reset the ECU.
Old 03-16-2020, 05:47 PM
slimjim702's Avatar
So in regards to the engine I haven't done much besides a valve cover gasket and oil Pan gasket I change the opera lower ball joints the rack and pinion the high pressure line and the cv axles. The car has been on Jack stand for 3 weeks. Then when I started it up and it ran like crap I changed the spark plug wires and spark plugs. Then after starting it up It still sounded like ****. So i did a compression test then i changed the distributor the hole thing. Started it up and ran great. Took it for a drive. Came back home and it started sounding like **** again
Old 03-26-2020, 04:55 PM
hondaslave1342's Avatar
Honda are very picky with its ignition system..use OEM cap..put the stock wires back on and use denso or Ngk plugs only..
Old 03-26-2020, 05:58 PM
slimjim702's Avatar
Yea I did that and still having the same problem
  #17
Old 09-25-2020, 02:59 PM
Did you ever figure out the issue. I'm in the same boat and have spent about 1000 dollars trying to solve my problem and still at a loss
  #18
Old 09-25-2020, 03:09 PM
slimjim702's Avatar
Yes I did and it was the egr . never would have thought it would have been that but that was the problem. Let me know if that fixes your problem
  #19
Old 09-25-2020, 05:09 PM
was it the valve, control valve or solenoid valve
  #20
Old 09-25-2020, 05:11 PM
slimjim702's Avatar
solenoid valve
Quick Reply: 1995 honda accord vacuum leak
