1996 accord ex
new update: i cleaned the throttle plate with carb cleaner. while i was spraying in the lower port inside of the throttle body, i noticed the cleaner was leaking out towards the firewall. i then removed the throttle body and noticed the gasket torn, so i replaced it. i test drove it seemed to do great until i went downshifted and punched it. i switched to 4th gear and it wouldnt go past 5k rpms. it kinda felt like the limiter was kicking in. before i was able to push it to 7000 without the limiter kicking in. i then put it in neutral and then it cut off. ive also noticed when the rpms get really low, the oil light flashes. im sure this is normal because of the rpms.
update: 4/30/13. on my way home, i noticed the engine started knocking really bad. im thinking its probably one or more crankshaft bearings. i hate to say it, but im going to have to get rid of it. i hate to see it go, but ive had fun in it.
dswiz1984
10-17-2008 10:10 PM
