1996 Accord F22 SOHC
I bought a not running accord I re-timed it and it started and runs great. Once i took it around the block and noticed the car warmed up, it dies out. So far I have cleaned the egr, and maf. I know that when i first got the engine running 2 misfire codes and a cylinder position sensor code came up. I deleted those and they have not came back and currently it will die out but once it dies no light comes on. any input ?
You haven't cleaned the MAF because the car doesn't have one of those.
When it warms up & stalls, will it re-start? Can you keep it running with the throttle (but it just won't idle)?
Try setting the base idle. It might be that the FITV is holding the idle up so it doesn't stall; UNTIL it warms up.
https://www.hondaaccordforum.com/for...e-speed-38734/
If it WON'T re-start, then you have to figure out whether it's lack of fuel or lack of spark.
^ agree, I might add the IAC cleaning as well.
New wires is what you need.
