1996 Honda Accord 140,000 miles WOBBLE at all speeds
Old 09-03-2008 | 04:45 PM
mphonda
Default 1996 Honda Accord 140,000 miles WOBBLE at all speeds
My 1996 Accord has aslow wobble with any forward movement to a rapid vibration at speed. Obviously speed dependent. Such a wobble at slow speeds would rule out an alignment issue, no? I have not hit any curbs or any large potholes. It just started one day, very faint. Now it is worse.
Thanks in advance.
-Matt
Old 09-03-2008 | 04:54 PM
08coupex's Avatar
Default RE: 1996 Honda Accord 140,000 miles WOBBLE at all speeds
i could be warn front end parts like ball joints. Warpped rotors also.
Old 09-03-2008 | 05:53 PM
deserthonda's Avatar
i strongly suggest that you chk your tires
Old 09-03-2008 | 06:07 PM
mphonda
Ok I had both front tires off and visually inspected everything and things (ball joints, tie rods, cv boots) looknormal. I am thinking its the tires because I swapped the front two wheels/tires and went for a short drive and it feels to be a slightly different wobble.
Any other thoughts?
Old 09-03-2008 | 06:11 PM
on our DIY section there is a write up .. cannot recall what page,, but if you scroll around you will find it .. it still sounds like tires to me ( broken ply)
Old 09-03-2008 | 06:25 PM
mphonda
Thanks! Did a search before posting and nothing came up under "wobble" or "vibration" my apologies.
VR
Matt
Old 09-03-2008 | 06:27 PM
falkore24's Avatar
Did you try wobbling the wheel with it on the car, but off the ground? There are a lot of possibilities, but I think that the most likely are ball joints or tires like DH mentioned. Could be as simple as wheel weights.
Old 09-03-2008 | 07:01 PM
mphonda
A quick and huge thanks to the heads up on the tires. Achem's (sp?) razor I was looking at all the suspension and front tires/wheels. Turns out when I decided to swap the rears to the frontto see if the wobble goes away, I noticed the rear driver's side tire has a HUGE bulge in it. Big time. I'm not even going to drive it to the tire shop. I took all four off and will take them down to have four new tires replaced. Acquired the car when I married my wife so I have no idea how old the tires are. She purchased the car used.
Thanks again.
-Matt
Old 09-04-2008 | 10:19 AM
falkore24's Avatar
Glad it's nothing more serious.
Zarcu
03-31-2013 09:40 PM
xray328
09-20-2011 06:37 PM
jlambo86
02-07-2011 01:20 AM
kylej2282
07-31-2009 12:53 AM
03-06-2007 09:27 PM
