1996 misfire
Old 08-23-2012 | 12:31 AM
Perla's Avatar
Default 1996 misfire
I have a honda accord lx 1996 4 cylinder. A month ago I remplaced a hose that was leaking water and making the car getting hot. Afer I remplace that house the car start working wear, until one day driving it, it turn off and do not turn on again until the next day turn on very good and smooth. Since that some times turn off while running and some times I have hard time turning on. I remplace the distributor, cables and spark plugs, I took to clean the injectors, remplaced the battery and fuel filter and after that the engine light turn on, supostly is a missfire on the 2nd cyl or a vacum leak, I do not know what can be causing my car to turn off while running
Old 08-23-2012 | 01:01 AM
I started a new thread with your post. Your car is different than the one you posted on, plus two problems on one thread makes things confusing.
What is the actual code? It will start with the letter P and have four numbers, like P1234.
Old 08-23-2012 | 01:19 AM
Hello new member..Tex will hook you up with a good answer..
Welcome to the HAF..
Old 08-23-2012 | 08:02 PM
Ang......I think you mean PA
OP- As PA asked, get the codes. Was the hose that was replaced near the dist? So could have coolant gotten into/on to the dist and caused the issue, I know a reach.
david8017
06-19-2014 01:12 PM
Muskiebri
04-22-2013 07:10 PM
TYTALEX
03-19-2006 01:57 PM
maffuh
01-27-2006 07:47 AM
05-15-2005 08:40 PM
