1997 Accord EX 2.2L Auto
Old 01-02-2008 | 08:51 PM
dwlfords
Default 1997 Accord EX 2.2L Auto
I have a strange situation. On cold start ups the engine runs smooth,when fast idle cuts down to normal idle, engine light comes on car misses and wants to stall. Engine code reads #1 and #2 Cylinders miss firing.
1) pulled off plug wire #1 engine acts like its going to stall only on cold start up, after engine warms upif you pull plug wire enginedoesnt have any miss like cynlinder not firing.
2)pulled off plug wire #2 engine acts like its going to stall only on cold start up or if engine isrev up to or above 1500rpms, after engine warms upif you pull plug wire, while idling,enginedoesnt have any miss like cynlinder not firing.
3)Cylinders #3 and #4 have no problems in any of the above mentioned situations.
4)Connected device in between spark plug and Wires on all 4 cylinders, throught all situations, device showed fire in all instances.
5)Check compression in all cylinders 155 - 165psi.
6)Change distributer cap and rotor (no change)
7) Check coil resistants (good)
So if anyone could direct me in the right direction on what to look at or knows what might be the problem I would be greatly appreciative
I was thinking
FUEL INJECTORS.....but unsure
Old 01-03-2008 | 08:06 PM
HondatechAV6's Avatar
Default RE: 1997 Accord EX 2.2L Auto
make sure the plug wires are in the correct order on the dizzy.
if ok, check the ignitor terminals - make sure they are on tight and securely(unlikely to be the cause, but anything is possible)
jessedavid
08-14-2012 08:03 AM
josherr82
03-11-2012 10:23 PM
ryandamartini
08-15-2011 10:18 PM
57explorer
04-27-2010 01:15 PM
new2hondas
02-12-2009 07:32 AM
