1997 Accord EX gauges not working. Please Help!
I just bought a 1997 Honda Accord EX coupe 4 cylinder. The speedometer, odometer, and fuel gauges do not work. Everything on the left side of the cluster works ( temp and tach), everything on the right doesn't. Any help would be greatly appreciated.
The speedometer/odometer can be a different issue than the fuel gauge, and will require some testing.
What is the speedometer doing? Does the cruise control work on the car? Is the check engine light turning on?
As for the fuel gauge. In the trunk near the back seat, there is an access panel that has 3 screws holding it in. Remove that panel and unplug the three pin connector. With the key turned to the II position (don't start the car), check that there is 5-8 volts between the yel/blu and black (ground) wire using a volt meter. Let us know what you find.
TOMMYgunn017
03-07-2011 01:00 PM
