1997 Check Engine Light (4 cylinder)
Old 03-13-2014 | 04:20 PM
jerrym's Avatar
Almost A Senior Member
Cool 1997 Check Engine Light (4 cylinder)
Hello All,
Today while driving into work I noticed the CEL lit on the dash of my 1997 Accord SE.
A short time later I noticed the speedometer not working, so realize they are both most likely related.
Has anyone experienced a similiar problem or have an idea of what might need repair?
Appreciate any suggestions!
JM
Old 03-13-2014 | 05:37 PM
RobinsonRicer's Avatar
Get the code read. You can do an auto parts store. If they are related it could be your Vehicle speed sensor on your transmission. But thats a wild guess without knowing the code.
Old 03-13-2014 | 08:36 PM
jerrym's Avatar
Just jumpered the 2 pin connector under the glove box (as decribed in the DIY section by PAhonda) and getting one long flash and seven short, so it looks like code 17 is present.
Now need to check into that.
Old 03-14-2014 | 11:49 PM
Just as I thought. Vehicle Speed Sensor.
First check the fuse. Under dash fuse, No. 1 (10A) Fuse. Make sure its not blown.
Then you can check the wiring first at the sensor.
Black should have continuity to ground.
Yellow should have battery voltage with the ignition on
and orange should have 5v with the ignition on.
The sensor is on top of the transmission housing I believe. Should be in the same general area whether its an auto or standard.
Old 03-16-2014 | 10:19 PM
jerrym's Avatar
Cool
Thanks for the info RR.
I checked the fuse, which is ok. Also the speedometer was working intermittently, so also thinking sensor.
Ordered one on Ebay, and will install and hopefully everything will work fine then.
JM
Old 03-19-2014 | 11:05 AM
No problem. It could always be the wiring but its not too uncommon for the sensor itself to go. Let me know if it works out.
zfcastle
07-30-2012 05:07 AM
zazer
01-20-2012 02:35 AM
anandram
07-06-2010 12:05 AM
PJ_STYLES_95AccordEx
10-24-2007 10:58 PM
