1997 front end changes from 1994?
Old 11-20-2006 | 09:05 PM
Guest
Default 1997 front end changes from 1994?
Alright, heres the deal. The front end of my 1994 Accord is messed up from a wreck. Front hit at about 15mph. It is definatly fixable. As for outside details: the front bumper is broke in the middle, the hood is bent back, and the front corner lights are falling out. Under the hood: Radiator is bent a little from the middle, some frame is bent in the middle of the front. So what I'm looking at it a 97 Accord EX with a blown tranny. I know there were some changes from 94 to 97, but is everything at the front end interchangable??? Plz respond Thanks...
Old 11-20-2006 | 09:12 PM
sir_nasty's Avatar
Default RE: 1997 front end changes from 1994?
To the best of my knowledge it shoudl interchange just fine.... However make sure you get that radiator pressure tested if you are going to continue to use it... It'd suck to get all your body work done then blow the motor due to a bad radiator....
cindjo717
09-10-2007 02:17 PM
thunder_x
09-02-2007 12:05 AM
robdog
11-07-2006 03:59 AM
blackpearlv6
06-20-2006 06:06 AM
veedubxlr8r
12-17-2005 02:04 AM
