1997 Honda Accord Temp Gauge Fluctuating
Stop by a parts store and have the codes scanned. Your connector is behind the ash tray. Post the actual code on here. It will start with the letter P and have 4 numbers, like P1234.
I would still replace the thermostat and change the coolant. I suggest getting the Honda thermostat at the dealership, because it will open at the proper temperature.
Change the ATF every 30k miles or so? Maybe someone with a 97 has another opinion...
Yeah the recommended change cycle is 24,000 miles at least that's what I saw at Autozone.
Update: I just had the transmission fluid drained and refilled!
Here's the codes that Autozone scanners found: P0740
Just saw this: The Autozone clerk said that his instruments or whatever wasn't "telling me anything" and that I should take it to a mechanic.
Edit: I took it to Autozone to see why the check engine light was on - I didn't report to him any problems with the transmission so that was probably why he didn't mention the error code.
However, on the receipt it says:
Also: When I had the transmission drained and refilled, one of the servicemen said that the car was 1 quart of oil short... I was like "What the hell!" So now I have to go buy a quart of oil - I should've just had him do it.
On my way to ye ole' school this morning, the car(not sure which part of the car) made that revving sound again. I did a web search for the P0740 code and other people are having issues with the solenoid - It's either failing or about to fail, I'm not sure.
I priced a brand new solenoid at Autozone and they go for $219... I totally don't have $219 right now so I hope my car lasts me until I get my hands on the money. The engine, as I said, feels strong and reliable and the transmission up-shifts and down-shifts just fine even if it's a little bit clunky(especially changing to 2nd gear).
What do you guys think?
"Troubleshooting P0740"
Definition - TCC does not engage
Probable causes:
1. Open or short circuit condition
2. Poor Electrical connection
3. Failed TCC system
Probable causes:
One more thing: The car has somewhat of a rough idle. When I decelerate or step on the throttle it goes just fine, no shaking or any issues - just that when I idle it starts vibrating a little rough(not violently though). Should I have someone adjust the idler?
Thanks guys, you've been plenty of help to me so far.
More research on the issue:
Diagnostic Trouble Code Definitions Table OBDII and OBD1 Retrieval Methods
I found a used solenoid on Ebay for $50. It's supposed to fit a 1990-1997 4-cyl Honda Accord. Here it is: 1990-97 Honda Accord Transmission Shift Solenoid Set | eBay
- P0740 – Torque Converter Clutch Circuit Malfuction
#17
Please add your car info to you signature, especially now that this is getting to mulitple pages, yes I'm old so I can't remember what year this is by the second page... Please.
How much are you willing to do yourself?
For the solenoid, sometimes you can pull them and clean the ends and be ok.
Idle or vibration, do you know when the last tune up (cap, rotor, check wires, plugs, ect) was? Then look into cleaning the tb pretty good, old tooth brush, rag and cleaner and be sure to get the back side of the butterfly.
Last, does this idle/vibration only happen when the ac is on?
pirulino23
11-10-2010 06:18 PM
