1998 Accord flashing door,brake,battery, ABS light on dash
When driving the door, brake, battery and sometimes the ABS light will flash. It happens while coming up to speed then stops when I get to 50ish. The car seems the drive fine. I just started using the E-brake for parking and this is what happened. I stop using the E-brake and cleared the computer and is still happening, no code comes up when checking the computer.
Thanks Amber
Thanks Amber
Frist I have to admit this sounds very stange to me, also I have not spent much time with this gen.
Is this a 4 or 6 cyl. Have you checked all of the battery connections to be sure they are clean and tight. The alt belt is tight and not slipping and the output of that alt is good.
A slipping harmonic balancer can cause strange problems. Charge light will not illuminate, but battery will decline to point of engine quitting due to low voltage. The rubber bushing in the harmonic balancer separates allowing outer pulley to slip, preventing alternator drive belt from driving alternator fully.
I had this problem on an Acura TL and it took quite some time before problem was discovered.
Worth checking closely to be sure you're getting good voltage to battery. An inexpensive battery voltage monitor ( $15 last I checked) from Walmart stuck in cigarette lighter works well.
Mr. 99
02-06-2019 05:56 PM
john germer
09-08-2013 06:44 PM
sunshinegirl7681
01-30-2012 06:09 PM
victorywhity
03-24-2011 10:37 PM
wize_n
10-10-2008 07:49 AM
