1998 Accord Power Locks don't work
I have a 1998 Honda Accord with power locks. Power locks will not engage when you move the power lock switch. Locks do not lock/unlock at all. The car also has the feature to unlock all doors with the key from the outside and that does not work. I checked and replace the fuse for the door lock which is located by the passenger side fuse panel and still does not work. Manual locking/unlocking works.
Is there a relay or something else related to the power door locks that I can look at?
Will appreciate anyone's help. TIA...
RE: 1998 Accord Power Locks don't work
welcome to the forum! Did they all just go out at once or has this been a progressive issue? I'd also check the fuses under the hood to make sure nothing is blown there.... is there anything else wrong with the vehicle?
My car also has a control unit. Not sure what is inside, I would assume components such as relays.
The control unit is located in the driver's side door. It is a little black box with a harness going into it. I would check this next if the 1998 model has one. Look for the service manual on here, there is a site that offers it for free.
natwood68
02-24-2014 12:16 PM
Jcaleno
06-10-2012 09:08 PM
