1998 Honda Accord V6 Engine Light ON Code P1457. Please Help.
Hi HAF, I have a 1998 Honda Accord V6. I have the check engine light on for code 1457. I was told that my Evap Canister is the problem. I want to buy the whole piece so I searched on eBay and found two different Item which are supposed to be the same piece. Can you guys tell me which one should be? Thank You.
Dorman Vapor Canister Shut Off Valve Fits Acura CL TL Civic Accord Odyssey | eBay
98 02 Honda Accord EX V6 2dr Purge Vapor Canister Filter B30 | eBay
Those are not identical parts, and they are not labeled the same.
One is the EVAP shut valve. The other looks like a filter for the evap.
I did this repair on a friends car. You may want to label the hoses you disconnect to be sure you get them back in the right place. The hardest part is the screws tend to be very corroded. I got one out and the second one I had to cut out.
Here is a video on the repair describing exactly what happened to me.
@PAHonda thank you, very help full video. Can please send a link of a photo showing what the canister look like? I like to buy the entire piece. When I search for te canister only the EVAP shut valve and The filter for the evap comes up.
@PAHonda I found two pieces not sure which is. Can you please help me out again and thank you.
A) Emissions Fuel Vapor Charcoal Canister for Honda Accord Acura CL TL | eBay
B) 98 99 00 01 02 Honda Accord V6 Front Evap Emissions Control Canister | eBay
bigant
12-02-2008 05:10 AM
