1999 accord crank position sensor no signal
Old 05-26-2010 | 11:10 AM
dineromike1's Avatar
Default 1999 accord crank position sensor no signal
I'm workin on my buddys 99 accord and checked the code which is p1382 (crank position sensor no signal. Only # 1 cylinder is firing and 2,3,and 4 r dead. Changed crank sensor changed disturbuter.... Same ****! Put jumper harness from obd II to obd I w/ a civic sd computer and same ****! Narrowed it down to a short somewhere. Idk if this is a common problem on accords or what. Help me out please. I don't work on accords much so that's why I'm on here.
Old 05-26-2010 | 11:57 AM
I'm tryin to bypass it but need ecu wiring diagram... where can u find 1?
pondrun
11-08-2021 10:40 AM
Tyler Joyce
09-24-2012 09:52 PM
argarcia86
02-23-2012 07:49 AM
keefer
06-16-2008 09:29 AM
Quick Reply: 1999 accord crank position sensor no signal
