1999 Accord stalling, but restarting by itself
I have a 99 Accord LX 4CYL, AT, not in CA. (hope this covers it). It's got about 175K on it. A few months ago I was sitting idle and all of a sudden the car died. I thought I might have bumped the key with my knee or something because it started right back up and didn't have any problems. Anyway, since then at seemingly random times while driving the car will cut out for a second or so, when I'm driving on the highway it will automatically start back up. No check engine light or anything like that. It may happen three times in one day and then not again for a couple of weeks. When the car stalls, the only light that seems to always be on is the key light, others are sometimes on and sometimes off.
Two days ago I was driving in a parking lot in the rain and it completely stalled. I could not restart it while driving (pos 2 to 3), but as soon as I stopped and turned it off (position 1) and back on, it started back up with no problem. It is not running rough or anything like that.
I was trying to recall if every other time it died if it was raining, but I can not recall (live in FL so it rains a lot).
Until a couple of days ago, if it stopped then it would always restart within a second or two (without me touching the key or anything).
Any suggestions? Much appreciated.
Ok, so as an update. It stalled again during lunch. It is not raining, nor has it rained this morning. It was acting fine. I was in a parking lot. I stopped to let some people cross, and it instantly died. I had to put it in park, turn it all off and then it started back with no problems.
I thought about the ignition switch too. I actually took it to the dealer and had it replaced under the recall. When it has died I tried jiggling the key but no luck. Any other suggestions? Thanks for that one though
It was replaced *after* the stalling problem started.
PAhonda,
I will give you the normal tuneup items are well past their due date, the spark plugs are OEM (not original plugs though). The air filter is not that old, maybe 5K.
You think the solution could be as easy as that?
If I replace the plugs, is there a better brand to go with that ppl here prefer?
I'm sticking with the ignition switch, another slight possibility is the Main Relay. If you're not familiar with inspecting them, have a qualified mechanic look at it (takes 1 minute to remove and inspect), or you could purchase one for about $40 dollars and just swap it out to do a process of elimination. I have a detailed PDF on inspection and replacement of ignition switch describing all symptoms of a failing or failed part. send me your email if you would like it.
No luck wiggling the key, but try this...
Start the engine but then don't completely let go of the key.
Let the key spring back only enough so the starter motor quits running. You'll be holding the key just barely away from the normal running position.
Can you keep it running like that?
PAhonda,
So get a new cap, rotor and plugs. I suggest NGK plugs but that is me. When the old cap and rotor are off, look real good at the wires and connections inside the dist.
