1999 Accord Transmission Erratic Shifting
Ok, I recently purchased a 1999 Honda Accord LX, 4cyl. automatic...Knowing there was a transmission problem...I limp'd it home, while trans acts like it switches to neutral then regains traction after some time, also down shifts hard and erratic when slowing...I noticed there A LOT of trans problems in this era of Honda...I did drain the fluid and install 3 qts of Honda ATF DW-1 and also cleaned the soleniod screens located below battery tray...I have a 96 Accord that I just love, no problems whatsoever...Should I just drop the trans and repair/replace or is there a possibility it can be fixed w/o removal???? There were some codes stored before I recleared...One a gear ratio code, one a third gear soleniod code...Thanks in advance...
Rilex
09-13-2013 08:35 PM
