1999 honda idle issues after timing belt change
Old 01-03-2013 | 01:11 AM
mike186abl's Avatar
Default 1999 honda idle issues after timing belt change
hi guys i just did a timing belt water pump seals the whole nine yards on a honda accord and i just finished it off and started the car up after topping off the fluids and when i started it up it had a really high idle like 5000 rpm so i shut the engine off ASAP what went wrong.
Old 01-03-2013 | 01:01 PM
High idle usually means massive vacuum leak; PCV disconnected, vacuum brake booster line open, etc. Inspect your engine vacuum lines carefully, esecially large ones.
mike186abl
03-22-2023 10:24 AM
KincaidChance
05-03-2011 02:13 AM
drummer1279
01-16-2011 10:34 PM
lvs4rock
10-28-2010 02:46 AM
