1999 ulev purge control solenoid
Old 02-16-2011 | 05:53 PM
jonmad99's Avatar
Default 1999 ulev purge control solenoid
does anyone know where the purge control solenoid is located on a 99 ulev 4 cyl.? or how to properly adjust the idle speed
Old 02-16-2011 | 07:19 PM
Front of the intake manifold, shown here as #8.
Look for stuff I wrote about BASE idle (probably in DIY).
Old 02-16-2011 | 07:21 PM
I think that is on the intake manifold near the fuel rail.
I think it should have two wires going to it, one will be blk/yel and the other red/yel.
The only other location would be near the evap canister that is under the car near the rear driver's tire.
Old 02-16-2011 | 07:34 PM
jonmad99's Avatar
yeah i saw the one on the front of the intake behind fuel rail but was not sure. i googled pics of the solenoid and it wasn't quite the same. but thank you. where did the diagram come from?
Old 02-16-2011 | 07:38 PM
It is from a site that sells OEM parts.
hondaautomotiveparts.com/auto/jsp/mws/catimgs/13s8401_e01.png
Old 02-16-2011 | 07:41 PM
www dot hondaautomotiveparts dot com
click PARTS
put in your car's information
select THROTTLE BODY for the category
Several on-line parts places have the same pictures, so I bet they come from Honda's electronic parts catalog.
Old 02-16-2011 | 07:42 PM
jonmad99's Avatar
thanks guys
grannie613
11-03-2014 03:16 PM
A Carter
06-10-2012 04:34 AM
A Carter
06-09-2012 05:10 PM
jhillblessed
05-10-2010 12:58 PM
jhillblessed
05-10-2010 10:55 AM
