2.2 EX Burning a Little Oil
Old 08-09-2006 | 11:26 PM
scottymac
Default 2.2 EX Burning a Little Oil
We just bought a new 06 Accord, and gave my son our '97 EX 4cyl. I noticed today a little puff of blue smoke when he started it up. It's only got 120,000 miles...could this be some type of leakage from valve stem seals, or should I worry about the engine crapping out on him? It's been running great. It's a little noisier than newer Hondas, but I've been told this is normal.
Any need to worry?
Old 08-10-2006 | 12:48 AM
mbo1985's Avatar
Default RE: 2.2 EX Burning a Little Oil
If the motor was cold and it was a tiny puff, I really wouldn't worry. Now if it does it warm, then there may be a situation. Just keep on taking care of that motor and it will last a REAL long time.
Old 08-10-2006 | 12:53 AM
MichaelEXL's Avatar
I have a little oil leak myself, the dealer told me when it will get bad enough to be fixed. I have a 96 Accord with 186,000
Old 08-15-2006 | 09:54 PM
fperezal's Avatar
Little puff at start indicates valve stem seals leaking a little oil to the pistons while sitting.. You could drive the car for another 150,000 miles and still this is not a serious issue, but it could get worse. Solution: replace valve stem seals, valve cover gasket and tube seals, for about 300 bucks. Meanwhile, change to a slightly thicker oil, it may help.
mamtsberg
05-30-2010 08:04 AM
jtimm07
07-31-2008 02:23 AM
live2rice
07-16-2008 09:34 AM
93EXWagon
04-08-2008 05:17 PM
accordinar
08-17-2007 02:07 AM
