2 different issues
2 different issues
I have been seeing the temp gauge near the top for quite some time and just Friday it pegged. Car is NOT puking coolant anywhere, ingesting it into the crankcase or burning it. The upper hose is hot, the lower is not. No excessive pressure in the cooling system. Radiator and coolant bottle are full.
My thoughts on this are a stuck thermostat.
I also have a CEL on as well. I have yet to check the codes and will likely do it at work on Monday. The car seems to have a miss while driving, intermittently. It usually occurs at part throttle while cruising, but does occasionally happen while accelerating from a stop.
My thoughts on this are cap and rotor. Plugs, wires, cap and rotor were new 2 years and 35K ago, but this is how it was acting then as well.
19accord92
04-10-2006 04:52 PM
