2000 Accord - Car "chugs/hesitates"
Old 06-05-2006 | 01:21 AM
siggy
Default 2000 Accord - Car "chugs/hesitates"
Has only happened in 4th, automatic tranny, only when lightly pressing the gas. 102k miles. SRS light is on. Check engine isn't. Haven't replaced the belts. Spark plugs are recent.
50-60 mph, rpm is about 1900-2100.
The car will chug 2-3 times, and I've noticed it more if I'm starting to go up a hill. But it's hard to reproduce, and sometimes it won't happen at all. Had the tranny replaced 9k miles ago, and it almost feels like that when it died (but it was slipping bad, which hasn't happened currently).
Maybe the fuel injectors are dirty?
Thanks for any suggestions.
Old 06-05-2006 | 05:54 AM
deserthonda's Avatar
Default RE: 2000 Accord - Car "chugs/hesitates"
what kind of plugs did you install????????
As for cleaning the injectors , it would not hurt at all... it is beneficial. wether that is the problem i am not 100% sure ..
you should fix the srs lite issue .. belts are under lifetime warranty ,,
Old 06-05-2006 | 10:36 AM
YeuEmMaiMai's Avatar
is this when you are comming up to speed and you let your foot off the gas ans the TQ converter locks up? If so, add a can of lubne guard to the trans (red cap) and see if that helps you out.
Old 06-05-2006 | 01:44 PM
good point by YEU.. i wonder if you are experiencing what we call torque convertor hunting.. goes in and out of lock up
Old 06-15-2006 | 07:23 AM
siggy
Found the problem.
The plugs/wires were toast. I tried to unplug 3 of the plugs, and they broke off. The plugs also looked like hell.
4 new spark plugs, new wires, runs fine. Never really had that happen before.
Old 06-16-2006 | 05:10 AM
Glad that it is fixed............AND
Thanks for letting us know what you found to fix it ..
devioustrap
06-01-2014 11:45 PM
Psyonic
05-29-2013 09:44 AM
Legend
02-21-2011 06:04 PM
jeffk14
11-21-2008 02:55 PM
