2000 accord clunking noise
Old 08-30-2005 | 09:00 PM
clforever
Default 2000 accord clunking noise
Hey guys,
I recently purchased a 2000 accord ex 4-cyl with 25,000 miles. For the past week, the car has been making a funny clunking noise coming from the bottom center of the engine. It makes the noise when I pick up the driver side fender and push it down. It makes this annoying noise eveytime I drive and go over a bump. I thought it might be my struts so I changed the front struts , but that did not help. If I pick up the passenger side fender and push it down, it does not make any noise, it only happens on the passenger side. The noise sounds like its coming from the bottom center of the engine. I checked both axles for any wear and they seemed fine, I also checked out the lower sway bar bushings and they too seemed fine. Any help would be much apprciated. Thanks in advance.
Old 12-03-2008 | 09:32 PM
99accordFX's Avatar
Default RE: 2000 accord clunking noise
Before I finished reading your post I was thinking sway bar links LOL. But they usually make a lighter bobbling noise. Hmm Umm try checking you ball joints for any play, also check control arm bushings and radious bushings. Really need to be there I guess the get full diag.
Old 12-03-2008 | 09:33 PM
cjdm98's Avatar
Whoa,This has to be the biggest bump in history.
Original post date:8/30/2005 9:00:16 PM
Old 12-04-2008 | 09:43 AM
jcocker03's Avatar
diagnose the problem before you start replacing parts. highly unlikely for struts to go out after only 25k.
Old 12-04-2008 | 10:21 AM
finch13's Avatar
LOL... wow might as well add my thoughts too. I'm think possible broken engine mount.
stockxplorer
09-25-2022 05:15 PM
Derekhhh
10-13-2013 04:14 PM
wkwarrior
06-22-2007 01:47 PM
anrebel1
01-31-2007 10:44 PM
corr04
07-26-2006 12:32 AM
