2000 Accord EX 4 cyl - Transmission error codes P0700, P1164, P1739 - my options?
Old 10-06-2009 | 03:56 AM
voteforpedro's Avatar
Default 2000 Accord EX 4 cyl - Transmission error codes P0700, P1164, P1739 - my options?
It's a low mileage car - 86k miles on it
I found this site initially when my Check Engine light alerted me to a possible Trans problem. I was hoping to avoid a Trans replacement by changing fluid hoping it would solve my problem - but after disconnecting the battery and resetting the check engine light - it again came on today - and a quick trip to Auto Zone - still having Trans problems.
I've got 3 codes
1) P0700
Definition : Automatic Trasmission Fault
Probable Cause
001 - Indicates trans fault - check other codes
2) P1164
Definition - Primary H02S ( no 1 ) circuit range / performance
Probable Cause
001 - Open or short circuit condition
002 - Poor electrical connection
003 - Failed H02S ( Heated Oxyben Sensor )
3) P1739
Definition - Automatic Transmission Concerns
This problem has been around for 2 weeks now - I'm driving my car as little as possible - but I think it's something I need to resolve in a timely manner so I can go back to having a reliable car again.
I'm open to suggestions - do I need a new trans - or solenoids? If I need a trans replacement should I go new or used - should I go junk yard? - should I go Honda brand - or can I go with an Autozone Transmission ( 800-1500 for transmission - after they get my old trans back as a trade in )
Cost is an important factor ( I'd rather not replace the Trans if possible ) - but I don't want to get my car fixed up - with parts that will cause problems down the road.
Thanks
Old 10-28-2009 | 11:58 AM
Mikkos21's Avatar
Well I have my 2001 Accord transmission replaced by honda a few years ago. At that time, I had 134,000 miles and today I'm currently at 298,000. I haven't had any other problems with it. Thank goodness! :-)
Old 10-28-2009 | 12:53 PM
00AccordLX5spd's Avatar
Registered User
You are gambling if you replace or rebuild the transmission. It is a common problem for the auto trans on 98-02 accords to go out. That's why Honda did the extended trans warranty (I believe being a 2000 model you are out of the warranty window though.)
I hate to tell you this but if I were you, I would get rid of that car and find something else (preferably not a 98-02 Accord with an automatic transmission.)
grannie613
11-03-2014 03:16 PM
Bigtom2000
10-22-2013 06:56 PM
JOE.G
04-09-2013 09:51 AM
voteforpedro
10-06-2009 03:54 AM
