2000 Accord rough idle and heavy oil usage
#22
The one all by itself is TDC. The two close together are for checking spark timing.
Try adjusting the valves first, before you pull the head. You may get lucky and find that the exhaust valves are just adjusted way too tight and not yet burned.
So I guess it's time to pull the head and see what's going on. Burned valves, carbon build up?
#24
Drive it for awhile after adjusting the valves on the loose side of the spec. If they've been tight there's bound to be carbon built up on the seats and valves and it may take awhile for that carbon to get pounded off. Not a fan of pouring liquid in the intake but in this case a top end cleaner of choice sucked thru the brake line booster line might help get rid of the carbon.
#25
I checked the valves today and the gap is perfect. If the valves were being held slightly open by deposits on the valves or seats I would expect there to be an increased gap between the valve and the rocker. If the rocker were out of adjustment and holding the valve open then there would be no gap at all.
#26
OK, the Honda is back on the road and running great. The head gasket was blown between 2 and 3 and the new PCV valve seems to have taken care of the oil issue. That intake is one huge pain to get off being that it's on the rear of the engine and has a bunch of electrical connectors up under it along with coolant lines too.
#27
Congratulations on job well done!
Did you rebuild the head or just install new HG?
Yes, removing the intake is a pain (same on earlier Accords) and requires a lot of lying underneath the car.
How was access to intake manifold bolts/nuts?
Brought the head in and had it checked, resurfaced and new guides put in. The access on the bottom, behind the engine is miserable. Likely better with a lift where you don't have to contort as much and can move around better. I've done about five or six in the past on different vehicles and this was the first one to seem almost insurmountable. Next time I'd just bring it in and pay the premium. It's also now got a new timing belt, balancing belt and water pump too.
#29
The OP has already solved his problem by having the head rebuilt and replacing the blown head gasket.
