2000 Accord Wont Start After Transmission Change
Old 12-17-2009 | 07:51 PM
NavyAg's Avatar
Default 2000 Accord Wont Start After Transmission Change
I've searched the forums for a similiar circumstance but cannot find anything to help. A buddy and I swapped out the A/T out of a 2000 Accord EX 2.3L that had over 300,000 miles on it and was slipping pretty bad between 1 and 2 gear. Installed a JDM "MCJA" transmission in place of the BAXA (I think since the sticker was gone). Installation was a breeze but had to replace two sensors from the old transmission to allow connectivity with the harness. Now the car will not start via the key but will start by jumping it at the solenoid and the key in the start position. I am unsure what to look for now and my daughter needs the car to drive back to take her final exam in college. Any help is appreciated.
Old 12-17-2009 | 08:38 PM
I am guessing that when you turn the key to start, nothing happens? Do you even hear a click?
I would check that both battery cable terminals have clean and tight connections on all ends (especially on the starter).
Also check that the 2nd connection on the starter from the ignition switch is clean and secured.
Old 12-17-2009 | 08:42 PM
Another test that you can try.
Have your daughter turn the key to the start position and hold it there. That second connection should have 12V on it by testing with a volt meter. If it does have 12V, hit the casing for the solenoid a few times with the handle of a screwdriver. If it starts up, then the solenoid contacts are worn out.
If that wire doesn't have 12V, then something upstream is wrong (like the a/t gear position switch isn't in park/neutral).
Old 12-17-2009 | 08:48 PM
NavyAg's Avatar
Thanks for the reply. It is cold and dark now and I will certainly try your suggestions first thing in the morning when it is only cold but with daylight. Been on this all day and do not have a garage.
Old 12-18-2009 | 10:24 AM
u2nv
seems to me you got problem with sensor on tranny doesnt think its in park or neut. make sure connectors r plugged in and no bent pins allowing no contact. also check adjustments on shift linkage. you could try to manual shift into park r nuet. if no start check wiring if does start adjust shifter
vboy
04-22-2014 12:43 PM
gasface11
07-11-2012 01:33 PM
KincaidChance
05-03-2011 02:13 AM
chris h
04-03-2011 11:01 AM
partsman1
11-05-2010 08:25 PM
