2000 EX 2.3l code P0301 and P1399
On my way home form work yesterday my check engine light came on and then began flashing. The car began to ride very rough and idle irradicly. I hooked up the OBD II and got the codes P0301 and P1399 (multiple cylinder missfires) I changed the plugs, the egr valve, and the O2 sensors. I started the car and after a few minutes the car began to iddle weird dropping from 1500 rpms to 500. Then the light came on again and it threw the same code. I disconected the map sensor and and noticed a difference in idle and did the same with the tp sensor. It seems like it could be anything. Any help would be greatly appreciated.
geoffm1234
07-20-2012 11:12 PM
patelmd
06-29-2012 02:15 AM
