2000 Honda Accord 3.0 Radiator Bleeding
Old 05-18-2012 | 06:31 PM
HondaRide531's Avatar
Default 2000 Honda Accord 3.0 Radiator Bleeding
Can anyone tell me how to Bleed the Coolant System in my 2000 Honda Accord V6 3.0 Engine. I changed the Radiator and Thermostat. Thank you.
Old 05-18-2012 | 07:03 PM
Here are instructions from the owner's manual. During the bleeding process, I usually feel the hose going to the thermostat housing to see if it is hot, if it is hot, then I know the thermostat has opened to help purge more air out of the cooling system. But, be careful about moving fans, belts, etc. ; you can also check this after you shut the car off to avoid accidentally touching any moving parts.
Attached Thumbnails 2000 Honda Accord 3.0 Radiator Bleeding-bleeding-cooling-system.jpg
Novaknowledgenow
05-30-2013 09:58 PM
hmr
03-28-2012 11:49 PM
Louay
03-15-2012 06:09 PM
Tek310
06-28-2011 12:52 AM
nmikmik
12-01-2007 12:14 PM
