2000 Honda Accord SE Cylinder Misfire Code P1399
Old 12-13-2012 | 07:53 PM
Stimn11's Avatar
We didnt replace the entire distributor just the cap and the rotor, Im not 100% sure what the fuel pump problem was since we never really diagnosed it just left it unresolved. It doesnt seem to be burning oil either
Old 12-13-2012 | 07:54 PM
Stimn11's Avatar
does anyone have a diagram of what the spark plug order is on the distributor just to make sure i didnt hook them back up in the wrong slot even though I'm 99% sure that i put the back correctly
Old 12-13-2012 | 08:04 PM
Silver6gen's Avatar
What kind of engine does it have?
F23a1 or F23a4?
The F23a4 has ULEV written on the valve cover. It should also say "F23ax" on the sticker that is on the cam wheel cover where the timing belt lives
Old 12-13-2012 | 10:41 PM
The spark plug wire order on the distributor cap for a F23A1 and F23A4 are the same, while it is different for a F23A5.
Attached Thumbnails 2000 Honda Accord SE Cylinder Misfire Code P1399-6th-gen-accord-distributor-cap.jpg
Old 12-14-2012 | 08:47 AM
And remember that the cylinders are numbered starting from the "front" of the engine, which is the end that has the external drive belts. So cylinder #4 is closest to the distributor.
Old 12-14-2012 | 09:48 AM
Dr. Drivability's Avatar
just more info, may or may not be related, but the P1399 is related to clogged EGR valve/intake ports and possible valve clearance issues.
  #17
Old 12-15-2012 | 02:42 PM
Stimn11's Avatar
Ok it looks like the wires were installed correctly. Also we did a compression test and that wasnt the issue either. It does have an A1 engine
  #18
Old 12-15-2012 | 02:55 PM
Stimn11's Avatar
it appears now that the car is starting up fine and will run for about 10 seconds before the engine starts to slow down and it shuts back off. It seems like it is not getting enough fuel and I have a half tank of gas too.
  #19
Old 12-15-2012 | 04:54 PM
Stimn11's Avatar
The spark was good, compression was also good, the injectors ohm out good and are not leaking. I was wondering if maybe the fuel pressure regulator could be a possible cause of the problem?
  #20
Old 12-15-2012 | 04:59 PM
See post # 10.
Tenoke
02-14-2015 10:59 AM
bobrae2011
08-05-2012 10:35 AM
geoffm1234
07-20-2012 11:12 PM
scomstock55
12-17-2011 05:43 AM
jmarcantel
12-31-2006 02:06 PM
