2000 in idle rpm's jumps or bounces up and down
Old 03-25-2010 | 10:54 PM
bougie_44's Avatar
Default 2000 in idle rpm's jumps or bounces up and down
I have a 2000 accord 2.3 v tec 5 speed. It happened once or twice before winter. Today it happened again . The car was parked. I started it and when idling I saw the rpm Gage jumping or bouncing up and down. Maybe from 1500 rpm's to 2000 rpm's ( more or less) I drove for a few minutes and it drives ok. There is no check engine light. It drives good but gas milage could be better. What can be the problem? Thanks
Old 03-26-2010 | 07:34 AM
You say you noticed the tach bouncing up & down...
What about the engine itself? Is it actually revving up & down or is the tach flaky?
Old 03-26-2010 | 07:45 AM
chip's Avatar
+1 It sounds like a sensor problem. If the engine speed insn't "bouncing" with the tach, then it's prolly your VSS. If it is, then it's prolly the idle air valve/sensor.
Old 03-26-2010 | 07:59 AM
No, the VSS is for the speedometer. The tach signal comes from the ECU.
If the engine is actually revving up & down (sorta common), that could be a problem with the IACV. Or maybe it just needs the BASE idle set properly.
Old 03-26-2010 | 08:15 AM
chip's Avatar
Right, but won't a bad sensor signal still cause the tach to bounce? (correct me if I'm wrong here.)
Old 03-26-2010 | 09:46 AM
The VSS measures the road-speed of the car, so if it were flaky, that would ultimately feed to the speedometer (not the tach).
The engine RPM comes from the ignition timing signals (crank & cam sensors) first to the ECU. Then the ECU generates a tach-signal to drive the tachometer needle. (On older Accords the tach signal is generated directly by the ignitor inside the distributor.)
Old 03-26-2010 | 10:32 AM
bougie_44's Avatar
to answer your question: The engine is actually reving up and down not just the tach meter.
Old 03-26-2010 | 10:37 AM
bougie_44's Avatar
So I should check the iacv? Any other suggestions?
Old 03-26-2010 | 11:03 AM
First verify all of these things:
- no vacuum leaks
- no air in cooling system (really!)
- throttle plate & throttlebody bore are clean
- throttle closes completely
- accelerator cable goes slack, at least a little bit
BASE idle setting:
- find the idle-air screw, recessed in a hole above the throttlebody bore
- engine all warmed up, all loads (electrical & AC) turned OFF
- unplug wire from IACV (engine wants to stall - nurse it with throttle)
- adjust idle-air screw for 550rpm
- - (if the radiator fan runs, wait for it to stop)
- turn it off & plug everything back in
Force it to re-learn the idle control behavior:
- reset ECU by pulling fuse #13 in fusebox near right-front door hinges for a minute
- let the engine get cold
- start the engine without touching gas pedal
- let it warm up completely without touching gas pedal
Old 03-26-2010 | 07:58 PM
chip's Avatar
Well Jim, it appears to me that you are obviously the man, so thanks for your input!
Just to clarify, even if the ECU is getting bad information from a sensor like the VSS, that WILL NOT affect the signal the ECU sends to something else, like the tach????
Quick Reply: 2000 in idle rpm's jumps or bounces up and down
