2000 LX Cruise not cruising
2000 LX-5 speed manual
Cruise worked fine to work, non-functional on the ride home. The cruise switch on the left dash no longer shows a lighted indicator when the switch is depressed.
Checked fuse, (left side of dash labeled cruise?), couldn't find one under the hood. Fuse OK
Any help would be appreciated as I use it all the time.
Thanks!!
Thanks!!
RE: 2000 LX Cruise not cruising
Follow-up: I removed and replaced all the fuses, and disconnected, cleaned and reconnected all of the connectors I could find without reference to a schematic and I now have a functioning cruise control. The green LED on the Cruise Disconnect on the dash still does not function, (the switch will still kill all cruise functionality however), but I think I like it better that way as that indicator was quite annoying at night.
Thanks!
Thanks!
pimpp1184
03-18-2010 05:46 PM
ford
05-01-2008 09:13 PM
