2000 V6: Front Engine Mount?
The dealer says my front and right-side engine mounts are "broken." Rather than pay the $600 or so they want, I think I can do the job myself.
With regard to the front mount... it looks like a "genuine Honda" mount is well over $100 while an Anchor mount from RockAuto is around $43. The Anchor mount says, "Does Not Include Vacuum Line Fitting or Nut." Does that mean it is a solid mount that does not connect to the vacuum engine mount control system? If it does not, is it going to make a big difference?
It likely means the mount is solid rubber and may be much stiffer than OEM. Effect will be lots more engine vibration at idle, but I don't know if it would be tolerable or not.
You may want to look at used parts; ebay primarily for this part.
This is not a trivial job on V6 engine. Rear mount may require lowering subframe to access. Forward mount is accessible, but difficult. See following excellent video. Remember, this is the easy one.
I would be sure the rear mount needs replacement by close inspection (if visible) while shifting to D & R and observing motion and looking for physical damage.
d0n
02-20-2013 09:17 PM
baer77
02-27-2009 04:47 PM
